May 08, 2024, 06:58:50 AM *
Author Topic: doin a titan swap  (Read 40483 times)
« on: June 10, 2008, 10:16:56 PM »
well i had the stuff sitting in the garage for a while , wasnt sure if i wanted to do it cause the extended axles are
$560 , well i talked to an offroad shop and they said quite a few people have cut the axle in half and sleeved them with a piece of chromoly , well since i had an extra set of shafts i decided to give it a go , worked out pretty well just got to do the other side then get tie rod extensions and longer brake lines , ill probably get tc uca or prg uca later down the road , but money is tight
kept the frontier spindle , but you can replace the spindle with a titan spindle to get the 6 on 5 or whatever the bolt  pattern is gained another 2" of down travel but havent tested up travel yet
« Last Edit: June 10, 2008, 10:22:23 PM by penski61 » Logged
« Reply #1 on: June 10, 2008, 10:57:26 PM »
looks good man Thumb-Up
let us know how the trail test goes.
I do have a ? though... would one be able to take titan outters front and rear to convert fron the 6-on-funky bolt pattern to 6-on-5.5 from the titan?
« Reply #2 on: June 11, 2008, 07:31:09 AM »
yeah you could do it 2 diff ways , upfront u have really one option
use a titan spindle
rear switch to a titan rear axle , or buy adapters
i already had the adapter for the regular lug pattern and to keep the track width the same as the front youll need the adapters , only thing i dont get to keep are my steelies cause they will be sticking out way to far in the front , so no adapter in the front and adapter in the back
NismoCC
# ./lock -diff
« Reply #3 on: June 11, 2008, 10:29:16 AM »
Very Cool Penski.  I can't wait to see how this works out on the trail.  Just as I thought I may be starting to catch up just a little, you leave me in the dust again... haha.  Which is very cool might I add.  Thumb-Up
07 Nissan Frontier CC Nismo 4x4
07 Toyota FJ Cruiser 4x4
« Reply #4 on: June 11, 2008, 09:17:11 PM »
mcm4090
« Reply #5 on: June 12, 2008, 07:02:40 PM »
Nice!
« Reply #6 on: June 13, 2008, 07:24:27 PM »
just need to get the rims swapped over and get a shop to bleed the lines right
X_Trippin
« Reply #7 on: June 14, 2008, 03:24:57 PM »
Thats so cool, looks like there is way more down travel do to the fact that the UCA's are no longer hitting the spring bucket.
RuggedRocks on AIM!
AMSOIL Referal #1714095
« Reply #8 on: June 14, 2008, 04:57:05 PM »
they still hit the coil bucket but due to the diff length of the frontier and titan uca that is the reason for more down travel  Thumb-Up
but had to switch back to nismo rims , and my gosh steelies are alot heavier
the007forum
« Reply #9 on: June 16, 2008, 06:30:27 PM »
nice! im still deciding if i want to do it that way or wait till i can get PRG titan uppers and bigger coilovers. how easy was the axle swap?
« Reply #10 on: June 16, 2008, 09:30:05 PM »
dont know :-P , i cut and sleeved mine haha , but ill eventually get the ones from prg
goin stock uca and lca from the titan still makes a huge diff over frontier uca and lca
« Reply #11 on: June 27, 2008, 08:19:00 PM »
new pics got some new stuff Smiley
2.5 saw's
titan prg uca's
mt_wi86
« Reply #12 on: June 29, 2010, 02:21:28 AM »
Hey Penski, Are you happy with your DIY extended axles or would you suggest PRG/SAW? How much exactly did you extend them??
« Reply #13 on: June 29, 2010, 07:05:54 AM »
extending them was a temporary thing that last a few weeks , i have the ext axle shafts from prg and havent had any issues with them
« Last Edit: June 29, 2010, 07:19:49 AM by penski61 » Logged
« Reply #14 on: August 09, 2017, 05:38:42 PM »
In case anyone needs extended/ Titan Swap R180 axle shafts, you can find them online from Rugged Rocks here:
https://ruggedrocksoffroad.com/index.php?route=product/search&search=R180%20Titan%20Swap%20Axle%20Shaft
