April 15, 2024, 09:00:03 PM *
Author Topic: 92 nissan d21 sd25t turbo diesel sas  (Read 31472 times)
ehtrain
« on: July 14, 2014, 09:14:42 PM »
ok as I promised steve when I purchased some of his parts recently I would post my build
Real Name: Jason
Year:  1992
Make:  nissan
Model:  custom
Trim:  not much left
Color:  grey
Mods:
-my own rebuilt & blue printed sd25 nissan diesel
-my own turbo kit
-ebay turbo at 6psi
-my own stainless oil pan
-4x4 oil pump
-ka24e gas swap for trans
-rebuilt 5spd
-spec stage 2 ca18det clutch
-tx-10a front adapter flange from ruggedrocksoffroad.com
-my own tranny cross member
-93 short box h233b axle in rear
-2.5in wheel spacer in rear
-longer rear shackle
-rear helper springs
-5.13 nitro gears in rear from ruggedrocksoffroad.com
-all new rear drum brakes/hardline/stainless braided soft line
-bilstien shocks in the rear
-1pc drive shaft in rear
-82 wagoneer front axle and springs
-my own heavy duty steering linkage
-custom shortened front drive shaft with 1310 cv flange
-5.13 motive gears up front
-detroit true trac torsen diff up front
-rancho shocks up front
-my own shock towers up front
-stainless braided soft lines to front calipers
-97-01 dodge 1500 4x4 master cylinder
-35x12.5R15 bf all-terrain tires
-chevy 15x8 6 bolt wheels
-3inch body lift
if you want to read about more of my build and all my triumphs and failures then check here lol. http://nissandiesel.dyndns.org/viewtopic.php?f=4&t=2923&sid=c343d7292f2d1022d6545e9341bef15f
« Last Edit: July 21, 2014, 09:42:30 PM by ehtrain » Logged
« Reply #1 on: July 15, 2014, 01:38:32 PM »
Nice! Do have any video?
Also like how you got 2 batteries under the hood!  cheers
ehtrain
« Reply #2 on: July 15, 2014, 05:10:46 PM »
thanks!
I will post some videos soon.
Ya those batteries took some fitting to get the filter block in there also. I'm thinking switching or trying to get td27t airfilter box in and water proofing it. this may give me room for a 3rd battery as the d21/wd21 diesels have the second battery where my air box is.
ehtrain
« Reply #3 on: July 21, 2014, 09:00:58 PM »
crappy video of me going through river this weekend when camping
ehtrain
« Reply #4 on: September 12, 2014, 06:32:33 PM »
made some new parts for the pig.
ehtrain
« Reply #5 on: September 12, 2014, 06:50:16 PM »
took a week long trip to waiparous alberta area. or the "ghost lands public use zone" and did about 100km worth of some amazing trails.
Now i'm looking forward to my next trip somewhere. anyone got suggestions?
ehtrain
« Reply #6 on: October 01, 2014, 06:40:22 PM »
 must give appreciation to nissan nut. your website has helped me with a lot of modifications. Some of the info I have gotten from your personal webpage has been invaluable to me.
ok so on my mountain trip I wore the slip yoke out of my wagoneer front driveshaft. It was giving me a real nice SNAP noise if I downshifted in low gears and wasn't careful. I went about finding a new slip yoke and splines online. To my surprise it appears spicer updated the shaft and spline sizes for the 1310 stuff after 81. So my front drive shaft is 1.78in OD tube with a 1.2 in OD spline. I don't know how long the spline to yoke contact surface is.
I went to local junk yard and pulled a drive shaft from a 1990 jeep cherokee xj. This had a good slip joint and the newer 2in od tubing and 1.3in od splines. From info I found on this forum and nissan nut webpage. I tracked down all the spicer numbers to make a high working angle drive shaft. this uses 1310-1330 conversion u-joint along with a 1330 center yoke on a 1310 cv driveshaft. the ID of the 1330 yoke is slightly larger then the 1310 center yoke allowing the center cv ball to rotate to its maximum angle. I also clearance my drive flange abit to make sure the 1330 center yoke wouldn't contact anything. then had it balanced and shortened to 24-27in working length from the 31-34in off the xj
not much more angle but it's there. plus the drive flange is missing off the wagoneer drive shaft so the center yoke is allowed to go abit further then it normally can.
new and old
ehtrain
« Reply #7 on: July 28, 2015, 04:03:59 PM »
very stable and far exceeded my expectations for handling for no sway bars on a tall truck on highway and hard corners. suspension seems to flex and take everything in stride very nicely.
on 2.5in lift rancho leaf springs up front
carjeep
« Reply #8 on: August 22, 2015, 08:01:54 AM »
what a great build!!! any chance of more videos?!
