April 25, 2024, 08:15:22 AM *
Author Topic: Newbie with a bad pinion bearing  (Read 10214 times)
jedavisss8
« on: April 02, 2014, 07:11:47 PM »
Hi All -
Have a '95 Pathfinder 4x4, LSD, auto.  The pinion bearing is going south.
I could:  Have my local shop rebuild the diff ($850)
             Try to do it myself (about $500 for the whole kit, and I've never done this)
             Get a replacement diff from a junkyard - not as reliable but a lot cheaper
Question:  what axle ratio do I have?  4.625 or 4.636.  Tag on the front fender says HG46.
Any help is appreciated.  The whine is getting to me.
p.s. - that's whine, not wine.
Jim
jedavisss8
« Reply #1 on: April 03, 2014, 05:38:45 PM »
Should have thought of this before. Went to the local dealer with the vin. Computer showed it has either 4.375 (hg43) or 4.625(hg46). Plate on the fender says hg46.
« Reply #2 on: April 03, 2014, 08:17:32 PM »
If you ever need to look anything up by vin in the future, give me a ring, I can do the same thing.
Also I thought I told you about the axle code on the fender.
Sorry if i didn't!  cover
jedavisss8
« Reply #3 on: April 05, 2014, 09:38:27 AM »
Hey Steve -
I'm finding a number of used differentials on Ebay which have rear disc brakes.  I realize I probably would need to get the calipers and pads and maybe a longer or shorter brake line, and the correct master cylinder.  Are there any other issues with doing this swap?  Also, finding some diffs that are not lsd.  Advantages/disadvantages of not having lsd off-road?
Just got the rig out of the shop for a check out and fuel leak.  Found out I also need both front axles as the boots on both are shredded. Hit
« Reply #4 on: April 09, 2014, 05:28:46 PM »
if I remember right the existing brake line is long enough.  Thumb-Up
LSD is preferable off road. unless you're planning on putting a locker in.
