April 25, 2024, 09:37:18 PM *
Pages: 1 [2] 3 4
Author Topic: Gen 1 Xterra (D22) Diamond Solid Axle Swap  (Read 103455 times)
« Reply #25 on: February 24, 2014, 01:28:21 PM »
We've got Tires!
 37's for this soon to be crawln X
« Reply #26 on: February 24, 2014, 01:30:15 PM »
Front End Goodies
poruja111
« Reply #27 on: February 24, 2014, 05:01:54 PM »
I am so happy you are doing this.  I want to do it with the minimum amount of altitude.  What is the minimum lift that this SAS will generate on a 2002 se?
« Reply #28 on: February 24, 2014, 05:16:57 PM »
So I take it the tires balanced out well then? Did they do clamp on weights or beads? How long are you figuring until its a roller?
« Reply #29 on: February 24, 2014, 06:37:06 PM »
Yup, each took less than 6 oz. so it was good!
weights on the inside. it should be rolling on Wednesday just needing gears and driveshafts.
(knock on wood)
« Reply #30 on: February 24, 2014, 06:48:04 PM »
You have convinced me Steven  Grin Just need the money now! Hit
Build is looking amazing.
« Last Edit: February 24, 2014, 06:50:17 PM by conor1123 » Logged
rawkerstatus
« Reply #31 on: February 24, 2014, 08:12:38 PM »
Springs are 200/250
This one doesn't have an EGR.
But please e-mail my any issues that you have with these headers and I'll forward that info to DT.
so thats 200 upper and 250 lower?and yea got those pics sent. itd be nice to get rid of the CEL. looking awesome. what size are those joints and where can  i get a set? and is that 1.75 DOM tubing you're using for the links?
« Reply #32 on: February 25, 2014, 08:56:01 PM »
yes 200 upper and 250 lower. the rates you want to run will change depending on how much uptravel you want and the ride height.. as well as the length of shocks.
forwarded your stuff to DT we were talking about that with them today when I went in there.
We'll catch up on that later.
« Reply #33 on: February 25, 2014, 08:56:25 PM »
Let me know when you're ready!
« Reply #34 on: February 25, 2014, 09:02:41 PM »
fish plates, Shock hoops and track bar bracket ... in!
« Reply #35 on: February 25, 2014, 09:04:42 PM »
Test fitting the new crossmember!
« Reply #36 on: February 25, 2014, 09:31:01 PM »
Wow this is coming togethor so nice. Thanks for all the updates!
« Reply #37 on: February 25, 2014, 09:36:41 PM »
That's an interesting take on the crossmember; I was curious how it was going to turn out. Did you hack off the old crossmember mounting points on the frame or does this one mount in the same spots? I can't really tell because of the light from the other side of the pic. I see what you mean now when you said the exhaust was going to have to be re-routed a bit.
« Last Edit: February 25, 2014, 09:43:17 PM by CaptainMorgan_SOS » Logged
« Reply #38 on: February 25, 2014, 09:50:21 PM »
Yeah we had another one out of square tube but there was a small interference issue with the stock tcase linkage. so we decided to do it this way. It's easier to reproduce this way anyways.
poruja111
« Reply #39 on: February 26, 2014, 07:49:02 AM »
Starting to look pretty high.  Will the kit allow me to decide how low or high I want to go?  I don't want to go with 37 inch tires, rather 31 or 32 inch.  Don't want the rig to be in the clouds and have dinky little tires hanging there.
« Reply #40 on: February 26, 2014, 09:41:02 AM »
This is the exact same setup as my pathfinder and it willl sit about the same. We can lower it some by using shorter shocks and different springs. However this setup is way overkill for the type of wheeling one would do on 31" tires
poruja111
« Reply #41 on: February 26, 2014, 12:43:53 PM »
I wonder if I could order your current kit and cut it down some in order to stay lower?  If cutting down is doable, it might increase the market for the kit for those who don't wish to install oxygen tanks for breathing while driving.  I want the kit because it lets me get the 5.8 ring and pinions front and back, not bigger tires.
« Reply #42 on: February 26, 2014, 07:55:44 PM »
 running 5.8's with 31" tires doesn't sounds like a good idea
also the kit wont be sky high like your thinking on 31's yes it will make it look tall but the majority of people that want to do the solid axle swap want to run 35's or larger
« Last Edit: February 26, 2014, 10:28:45 PM by penski61 » Logged
« Reply #43 on: February 26, 2014, 08:00:28 PM »
Haha! I agree though. That would be cool if there was a different variant of the kit. But you are right also Steven, the kit is pretty much for the hardcore crowd and this kit is definitely overkill for 31s. Maybe a 33 would work?
I know right now i'm planning on on 35s, which I know you were previously running on your old d44.
« Last Edit: February 26, 2014, 08:02:04 PM by conor1123 » Logged
« Reply #44 on: February 26, 2014, 09:18:08 PM »
We wouldn't have to cut anything from the kit. Just use shorter shocks and different springs.
I recommend atleast 35s using 33s could probably work without extensive changes. But that's not something that im working towards.
If you're looking at doing this soon please pm me. Ill help you out a little but I wont be doing a prototype build like you're describing.
« Reply #45 on: February 27, 2014, 01:31:42 AM »
Steering Knuckles are on, and the hubs 'n spindles are together for the time being. they'll come apart again when the 3rd members go together and axle shafts are installed.
It's carrying it's own weight sitt'n on those sway a way coilovers!
« Last Edit: February 27, 2014, 01:34:14 AM by SteeevO » Logged
« Reply #46 on: February 27, 2014, 01:45:44 AM »
Although we still have a number of things to do, It doesn't need jackstands!
After some minor preliminary fender trimming, we threw the wheels n tires on, and stood back to take a look at it's current stance, which came out really nice.  cheers
It's slightly taller due to a minor design change in the shock hoops over the design that we used on the pathfinder. but the height definitely isn't way out of the park and lines up perfectly with the simple spring over conversion out back.
The spring over conversion on the rear was done with just a pair of leaf spring perches and relocating the shock mounts. Nothing super special is happening for the rear suspension for now but there are some plans for the future.
« Last Edit: February 27, 2014, 02:07:01 AM by SteeevO » Logged
poruja111
« Reply #47 on: February 27, 2014, 04:25:27 AM »
Is that sitting on 37's?  I think you are right.  I might be able to put 33's on that.  Thanks.
« Reply #48 on: February 27, 2014, 01:56:50 PM »
That looks great! So how much more trimming are you thinking on the fenders? It looks like the front side of the front wheel well is going to require quite a bit. Does it look like there is going to be any issues with the rear around the door area?
« Last Edit: February 28, 2014, 02:47:04 PM by SteeevO » Logged
rawkerstatus
« Reply #49 on: February 28, 2014, 02:03:47 AM »
lookin better everyday
Pages: 1 [2] 3 4
