March 28, 2024, 02:24:04 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: View our New trail run pictures in the
Image Gallery
Home
Help
Login
Register
Rugged Rocks
Solid Axle Nissan Pathfinder Project
> Topic:
Sway-A-Way Coilover Assembly
Pages: [
1
« previous
next »
Author
Topic: Sway-A-Way Coilover Assembly (Read 11050 times)
Offline
on:
October 03, 2012, 07:40:08 PM »
A step by step guide on assembling 14" Travel, 2.5" w/ Remote Res. Sway-A-Way Coilovers with a dual rate spring setup. It's very simple but this could pretty informative for that that have never done it before.
Pics will come soon.
Rugged Rocks Newsletter
| Check out my articles on
CrawlerNews.com!
cbrgoose
Offline
Re: Sway-A-Way Coilover Assembly
Reply #1 on:
January 14, 2013, 11:39:08 PM »
How was the performance of those 14's? What ratio are they set up for up and down travel?
Offline
Reply #2 on:
January 14, 2013, 11:52:07 PM »
so far they are great!
they are at about 6" up and 8 down.
The springs are 250/200. both at 14" long.
CrawlerNews.com!
Offline
Reply #3 on:
May 01, 2013, 07:09:44 PM »
I actually didn't get any pics of the coilover going together however, putting coil overs together is super simple!
When the shock itself comes from the manufacture, all you need to do is slide the top spring over the shock body from the bottom, then slide the spring isolator on after that, then the bottom spring, then the bottom spring retainer slides into place.
you'll then want to adjust the top spring preload adjuster down just enough so the springs don't float.
If you're running the correct spring rates, your truck will sit at the proper ride height without adding any additional preload.
CrawlerNews.com!
Pages: [
1
Rugged Rocks
> Topic:
« previous
next »
Please select a destination:
Rugged Rocks
=> Solid Axle Nissan Pathfinder Project
=> Announcements and Updates
=> New Member Check-In
=> Vehicle Showcase
=> General Discussion
=> Off Topic
On The Trail
=> Trail Runs and Events
=> Trail Run Reports
=> Trail Closures and Updates
=> GPS & Mapping
=> Communications
Vehicle Specific
=> D40 Frontier
=> N50 Xterra
=> R50 Pathfinder
=> D22 Xterra / Frontier / Navara
=> D21 Pathfinder / Hardbody / Terrano
=> 720
=> Patrol
=> Rock Buggy
=> Trailers and Towrigs
=> Jeeps, Toyotas 'n Other Stuff
Classifieds
=> Parts For Sale
=> Rigs For Sale
=> Parts Wanted
Loading...
