April 16, 2024, 02:56:02 AM *
Author Topic: Whats Next? Rugged Rocks Needs Your Input!  (Read 25758 times)
« on: June 18, 2012, 10:01:51 PM »
About a year ago Rugged Rocks was neck deep in all kinds of new product projects, and over the last year, one by one, new products were released and the list of open projects grew shorter and shorter. Progress!! Below is an updated list of products that were either new last year or were in progress. As you can see the number of open products has shrunk to just a few. Rugged Rocks has always been enthusiast driven and once again needs your input push the Nissan 4x4 aftermarket forward even further. What do you guys need for your trucks? Lets talk about it on the message board and get the ball rolling on some new products.
I really appreciate everyone's input and everyone's business.
Lets keep it going.
-Steven Lutz
Founder and President
Rugged Rocks, LLC.
Pathfinder/Hardbody 3.0L HD motor mounts
Available here: http://ruggedrocksoffroad.com/advanced_search_result.php?search_in_description=1&keywords=3.0+motor+mount
Xterra / Frontier 3.3L HD Motor mounts.
available here: http://ruggedrocksoffroad.com/advanced_search_result.php?search_in_description=1&keywords=3.3L+motor+mount
WD21 Pathfinder Long Arm 4-Link
available here: http://ruggedrocksoffroad.com/nissan-pathfinder-long-arm-rear-4link-suspension-bracket-joint-kit-by-rugged-rocks-1988-1995-p-36013.html
H233B/D60 Front Diamond Axle
available here: http://ruggedrocksoffroad.com/nissan-h233b-front-axle-housing-by-diamond-axle-p-36077.html
Pathfinder / Hardbody SAS KitWill be using a H233B/D60 Diamond front axle. Due to be completed by the end of 2012, hopefully before the end of the world!
H233B 31 & 33 spline H233B Chromoly ShaftsThis project was put on the 'back-burner' due to the lack of interest. But I would personally really like to have these made.
H233B 3-link brackets
available here:  http://ruggedrocksoffroad.com/long-arm-rear-3link-bracket-nissan-h233b-by-rugged-rocks-p-35934.html
H233B Carrier Adjuster Tool
Currently out of stock, no ETA due to lack of demand.
           http://ruggedrocksoffroad.com/nissan-h233b-differential-carrier-bearing-adjuster-tool-by-rugged-rocks-p-35919.html
Rugged Rocks Winch Fairlead
Out of stock, no ETA due to lack of demand. If these were to get made again, They would be black anodized before machining the "rugged rocks" text into them which would then show the writing on a black background.
TX-10 transfercase doublerDue to the order minimum with the manufacture, and extended wait times, and lack of demand, this project is currently stalled.
Xterra / Frontier 3.3L V6 Doug Thorley Headers
Available here: http://ruggedrocksoffroad.com/advanced_search_result.php?search_in_description=1&keywords=3.3L+headers
H233B Ring and Pinion gears
5.42 gears canceled due to lack of demand.
           4.63 (std & Rev.) 4.9, 5.14, 5.57 & 5.87 ratios are available here:
           http://ruggedrocksoffroad.com/advanced_search_result.php?search_in_description=1&keywords=h233b+ring+and+pinion+gears
pre-'05 Xterra / Frontier / Pathfinder - H233B 33-Spl Lockright LockerPowertrax (maker of lock right lockers) was sold off by Richmond Gear (Previous owner of Powertrax) to Midwest Truck and auto Parts Who has no idea what happened to this project, and the parts I sent into them were lost. The project has vanish into a puff of smoke and probably will not be happening. However, I have mentioned to Randy's Ring and Pinion that they should make a 33-spline version of their 31-spline locker (similar to lockright) as is available here:  http://ruggedrocksoffroad.com/nissan-patrol-spartan-locker-by-randys-ring-pinion-h233b-31spline-p-36117.html
Xterra / Frontier '05+ C200K Lockright Locker                         Available here: http://ruggedrocksoffroad.com/advanced_search_result.php?search_in_description=1&keywords=PTX-9214803100
Advanced Adapters - 4 Cyl Pathfinder / Hardbody Atlas Adapter
Have tried having AA make this but it hasn't happened.
           I can have the proper spud shaft made elsewhere to complete the 4cyl kit but I haven't due to lack of demand. If you are interested in this, please speak up!
TJM H233B (31 & 33 spline) Air Lockers
available here: http://ruggedrocksoffroad.com/advanced_search_result.php?search_in_description=1&keywords=tjm+locker
ARB (M205) Titan Front Air Lockeron the list for production in Australia but currently there is no ETA
Superior 4.10 & 4.56 Gears for Titan Front and Rear Differentials
available here: http://ruggedrocksoffroad.com/nissan-titan-ring-pinion-gears-c-284_845.html
3.0L Pathfinder and Hardbody Doug Thorley Headers
Having Doug Thorley put these back into production after their last bactch was made in 2006. They should be available within the next few months.
           http://ruggedrocksoffroad.com/advanced_search_result.php?search_in_description=1&keywords=3.0+header
« Last Edit: June 18, 2012, 10:13:54 PM by SteeevO » Logged
nissanclay
« Reply #1 on: July 06, 2012, 01:54:00 PM »
Would still like to see a rear disk brake conversion for 33spline front Frontier and Xterra.
« Reply #2 on: July 09, 2012, 11:25:11 AM »
Thanks for your input clay.
I was wondering if anyone was going to bring this up.
I'll make it happen.
Toro
« Reply #3 on: July 09, 2012, 03:45:34 PM »
The Xterra comunity seems to be gravitating towards you. I was wondering if you would consider carrying smaller ticket items like wheel spacers or suspension components.
« Reply #4 on: July 09, 2012, 08:54:23 PM »
I'll see what I can do on the wheel spacers.
What are you refering to specifically when it comes to suspension?
I really try not to step on PRG Greg's toes but if there is something he is missing for the second gen trucks, I'll check into it and run it by Greg.
Thanks for the input!
« Reply #5 on: July 09, 2012, 09:24:28 PM »
maybe ask superior about some 3.73 gears for the titan front diff that way i wouldn't have to re-gear the back lol
Toro
« Reply #6 on: July 09, 2012, 10:31:14 PM »
I see what you mean. Greg's a great guy and working with him is a great idea. Shoot, I have all of his gear going on my X.
     On a selfish note. Since locking, I'd like to see 4:10 gears for the R180. I have no idea what the market would be, but I would be willing to do what ever it takes to help.
     If it helps, I have a complete r180 3:13 and a carrier for a 3:69 and up r180 that I'd be willing to donate for mock ups.
« Reply #7 on: July 10, 2012, 08:19:43 AM »
Penski,
3.73 gears for the front probably aren't going to happen.
The Simple way to put it is, Superior is basically done making stuff for Nissan.
Toro,
The 4.10's for the front were never made or even attempted becuase the R180 has so many failures. We feel that the deeper gears would just put added stress on the housing that is can't really take.
Thanks for the input though guys.
Keep it coming.
« Reply #8 on: July 10, 2012, 04:56:29 PM »
lol doesn't surprise me
« Reply #9 on: July 10, 2012, 05:51:46 PM »
The last project was an insane amount of stress and now they are sitting on gears.
Morpheus
« Reply #10 on: August 19, 2012, 05:50:58 PM »
00-04 xterra sas kit?
00-04 xterra steering system
(i'm running total chaos system now, but would have liked options other than their $1200 kit, plus i think they're missing stuff from the kit that i may fab myself this winter)
98-04 pathfinder 1" strut spacers
(i can supply you with a set i had custom made if you require templates)
O2 sensor check engine light eliminators (seems like a easy up-sell to go with the doug thorleys)
I'll keep my thinking cap on...
« Reply #11 on: August 19, 2012, 09:15:01 PM »
Thanks for the input! keep it coming!
Jakx13
« Reply #12 on: January 20, 2015, 08:08:19 PM »
4-link rear end kit for the first gen, and low range tx-10.
« Reply #13 on: January 21, 2015, 06:00:20 AM »
interested in this: H233B 31 & 33 spline H233B Chromoly Shafts
