Offline
« on: May 27, 2012, 08:15:17 PM » |
Offline
« Reply #1 on: May 27, 2012, 08:42:03 PM » |
Thanks kenny, I'm going to tear into my box tomorrow.
Rugged Rocks Newsletter | Check out my articles on CrawlerNews.com!------------------------------------------ "When you hit the tree between the headlights thats understeer. Oversteer is when you hit the tree between the Tail Lights"
Offline
« Reply #2 on: May 29, 2012, 07:21:07 PM » |
So i totally understand where most people tap the box but when I tore mine down I figured why not tap into both veins on the same side of the box keeping both lines out of harms way? Is there a reason people haven't tapped into it this way before? The short vein goes back 5/8" of an inch but I don't see any reason why it can't be drilled a little deeper if needed. Without drilling it deeper and drilling the 7/16" hole for 1/4" NPT tap as far away as possible from the edge of the box, you'll have a min of 3/16" of material left between the hole and the edge of the box but technically since it's only 1/4" id pipe you can drill as far away as leaving 3/8" of an inch of material without restricting the flow.
« Last Edit: May 29, 2012, 07:56:10 PM by SteeevO »
Offline
« Reply #3 on: May 29, 2012, 07:45:38 PM » |
didn't penski do this? I thought I remembered seeing him post up on the AZ board about this w/pics on where he drilled. I only remember this as it's on my list for someday.
Offline
« Reply #4 on: May 29, 2012, 08:12:31 PM » |
their boxes are a little different than the box ive got 1st gen box
« Last Edit: May 29, 2012, 08:32:24 PM by penski61 »
Offline
« Reply #5 on: May 29, 2012, 08:38:21 PM » |
so it looks like the hardbody boxes have 2 veins to tap into where the 1st gen has the one vein and uses the reservoir in the box as the return
Offline
« Reply #6 on: May 29, 2012, 08:50:13 PM » |
that's interesting. So, how does the fluid get to the res. section of the box from the valve in the first place?
Does anyone have a picture of the valve section of of the box? or a pic of the box complete?
Offline
« Reply #7 on: May 29, 2012, 08:53:08 PM » |
Offline
« Reply #8 on: May 29, 2012, 09:36:21 PM » |
Thanks man,
I think i'm going to drill and tap it like I originally pictured, on both veins. We'll see how it goes.
Offline
« Reply #9 on: May 29, 2012, 09:53:08 PM » |
im sure you will be fine with that style box , but for the 1st gens id recommend on doin it the way i pictured
