April 25, 2024, 03:52:11 PM *
Pages: 1 2 3 [4] 5 6
Author Topic: My Buggy!  (Read 140917 times)
« Reply #75 on: November 06, 2011, 03:18:35 PM »
I'm running 16" airshocks and the driveshaft is perfectly inline with 4" uptravel.  I didn't do the math but my guess it will bind at full droop.  I'll check it when I get the lower link done.  But, I planned on using a center strap or suckdown with the airshocks anyway.  It'll work out nicely with the center drop diff!
« Reply #76 on: November 06, 2011, 10:28:03 PM »
Lookin good kenny, nice work as always
« Reply #77 on: November 07, 2011, 01:44:10 PM »
Schweet.   Thumb-Up  Can't wait to see it done.
« Reply #78 on: November 30, 2011, 08:52:34 PM »
Finally got a rear end!  Currie HD 9 " SF, 35 spline shafts!  Third member is being built.  Detroit, N case, 4.85's.
« Reply #79 on: November 30, 2011, 10:04:51 PM »
4.85's? why so high?
« Reply #80 on: November 30, 2011, 10:45:52 PM »
I'm running the H233b up front.  It already has 4.9's.  6.5's would be nice, though.  I want a lower crawl ratio but I don't want to spend 3g's on an atlas only to get 5to1.  It would be cheaper to go to a 9" front and run 6.5's, which would put me at about the same crawl ratio as a 5to1 atlas.  And, I don't want to run the NFW double since my DS is already so short.  I'll just run what I got for now.
« Reply #81 on: December 01, 2011, 04:14:04 PM »
I thought you already had a case with crawlers in it, or did that go away in the other buggy?
« Reply #82 on: December 02, 2011, 10:36:58 AM »
I bought my old Tx10 with the calmini gears in it back from Jason.  But, it still would be nice if I had a lower crawl ratio.  If I had 6.5's in the diffs or 5.4 in the t-case that would put me around 100-1 total crawl ratio.  Now, I have 74-1.
« Reply #83 on: December 02, 2011, 07:47:25 PM »
Awesome! I'll have to stop by and check it out when I'm home for the holiday season!
and if you change your mind on using ur old Tx10 with the crawler gears I call dibs!  Grin
« Reply #84 on: December 14, 2011, 03:20:50 AM »
For sure, Daniel!  I still need to fix up your shock mounts, too.
upper wishbone done and shocks mounted!
« Reply #85 on: December 14, 2011, 11:50:52 AM »
Good to see more progress.
« Reply #86 on: December 19, 2011, 01:17:05 AM »
It's finally a rolling chassis!
« Reply #87 on: December 19, 2011, 10:45:05 AM »
awesome dude. that looks sweet.
« Reply #88 on: December 19, 2011, 11:34:21 AM »
KOH here you come  Grin
« Reply #89 on: December 19, 2011, 11:36:32 AM »
yeah wheres the ls1 and coilovers? ill be your navigator
« Reply #90 on: December 20, 2011, 10:00:51 PM »
That fab work is a thing of beauty
« Reply #91 on: January 08, 2012, 02:39:18 AM »
still whittling away at it.
made a brake pedal:
steering column
radiator mounts
intermediate shaft:
gas tank:
« Reply #92 on: January 08, 2012, 12:47:48 PM »
after seeing it in person, pictures don't do it justice - nice work as always
« Reply #93 on: January 09, 2012, 12:37:42 PM »
I can't wait to see thing thing on the trail.
« Reply #94 on: January 20, 2012, 08:31:54 PM »
Very awesome Kenny, as usual!!!
I'm hoping to get on your build list in a few months if work keeps going along ok!
« Reply #95 on: February 14, 2012, 06:00:32 PM »
how much money do you have in tube so far?
« Reply #96 on: February 14, 2012, 10:58:23 PM »
Close to $1000.   Almost 300 feet.  It's a mix of 1.5" and 1" .120 DOM
« Last Edit: February 14, 2012, 11:18:55 PM by theking » Logged
« Reply #97 on: February 14, 2012, 11:02:41 PM »
thats not too bad. The reason i ask is I'm thinking of tubing up at least my engine and maybe my whole truck this summer. thanks.
« Reply #98 on: February 17, 2012, 11:01:39 AM »
What do you have left to do to finish?
« Reply #99 on: February 18, 2012, 10:37:00 AM »
Too much!  Exhaust, brake lines, throttle pedel, fuel and coolant reservoirs, wiring & switch panel, skid plates, and I want to build a truss for the front axle.
