April 24, 2024, 10:15:18 AM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: View our New trail run pictures in the
Image Gallery
Home
Help
Login
Register
Vehicle Specific
D21 Pathfinder / Hardbody / Terrano
> Topic:
Path 93 V6 ratios????
Pages: [
1
« previous
next »
Author
Topic: Path 93 V6 ratios???? (Read 12624 times)
Al Altuve
Offline
on:
September 05, 2011, 02:55:40 PM »
Hi, I'm searching for all gear ratios. It's a 1993 manual transmission, Pathfinder XE V6 engine??
First gear??
Low Range??
Axle??
Thanks, for your help...
Offline
Re: Path 93 V6 ratios????
Reply #1 on:
September 05, 2011, 08:11:09 PM »
First gear is close to 4:1. low range is 2:1. and axle is 4.3:1
cheers
Check out my articles on
CrawlerNews.com
Offline
Reply #2 on:
September 06, 2011, 11:08:31 AM »
Chances are you have exactly what TheKing said but you might also have 4.6 gears in the differentials.
Check the Driver Door jam sticker for a line that is labeled Axle Code and starts with HG4, it either says HG43 or HG46 depending on the ratio.
Rugged Rocks Newsletter
CrawlerNews.com!
Al Altuve
Offline
Reply #3 on:
September 06, 2011, 03:12:08 PM »
ok... thanks.... let me check...
I want to put 33 tires on it, it will be 285 75 R16... Should I change diff ratio?? to 4.88??
Offline
Reply #4 on:
September 06, 2011, 10:15:42 PM »
for 33's you can use 4.6 gears.
CrawlerNews.com
Offline
Reply #5 on:
September 10, 2011, 01:02:16 PM »
Don't know where you are, but I've got a set (f&r) of 4.6 gears I'm not using anymore. Cheap cheap.
Al Altuve
Offline
Reply #6 on:
September 11, 2011, 06:36:33 AM »
Yes it has a HG43... 4.30:1 on the diff... I'm pretty interesting in your gears. Do you have both, front and rear?? you can send it to me to an address at Miami, Florida.... And it will be in Venezuela in 2 weeks...
Offline
Reply #7 on:
September 12, 2011, 12:13:12 PM »
I have both front and rear sets w/shims for the front and what-not; they are out of a 2002 Xterra SC. You'd just have to make sure they'd fit your diffs (I don't know what's in your rig). The gears came out of a r200a (front) and H233b (rear).
Al Altuve
Offline
Reply #8 on:
September 15, 2011, 07:08:05 AM »
let me check, but I'm pretty sure it fits.... are the same diff...
Pages: [
1
Vehicle Specific
> Topic:
« previous
next »
Please select a destination:
Rugged Rocks
=> Solid Axle Nissan Pathfinder Project
=> Announcements and Updates
=> New Member Check-In
=> Vehicle Showcase
=> General Discussion
=> Off Topic
On The Trail
=> Trail Runs and Events
=> Trail Run Reports
=> Trail Closures and Updates
=> GPS & Mapping
=> Communications
Vehicle Specific
=> D40 Frontier
=> N50 Xterra
=> R50 Pathfinder
=> D22 Xterra / Frontier / Navara
=> D21 Pathfinder / Hardbody / Terrano
=> 720
=> Patrol
=> Rock Buggy
=> Trailers and Towrigs
=> Jeeps, Toyotas 'n Other Stuff
Classifieds
=> Parts For Sale
=> Rigs For Sale
=> Parts Wanted
Loading...
