April 25, 2024, 07:20:06 PM *
Author Topic: Solid Axle Nissan Pathfinder Questions.  (Read 12604 times)
akuria
« on: August 23, 2011, 07:33:29 PM »
I have a 1991 pathfinder looking to go SAS. What axles do you recommend? I know d44 but from what donor? also I plan on doing leaf f/r. I am planning on either 33" tires or 35". what gearing do you recommend for both and what lift do you recommend as well?
thanks
« Last Edit: August 23, 2011, 10:59:21 PM by SteeevO » Logged
1991 Nissan Pathfinder
All stock, right now, anyways
« Reply #1 on: August 23, 2011, 08:27:31 PM »
either a 1980's wagoneer axle or ford high pinion if you want the width , if you want a hp but not the width you can cut down the pass side to the waggy length and use waggy axles on that side
akuria
« Reply #2 on: August 23, 2011, 08:45:35 PM »
awesome. thanks. So if I want HP i can use ford without cutting the axle housing? I got a guy that will sell me his f/r axles from a 73 ford truck. They should work?
« Reply #3 on: August 23, 2011, 09:04:04 PM »
yeah they will be wide on a pathfinder , i think the 73' came with drum up front and rear so you'd have to swap the fronts out to disk
i have a 74 housing with waggy outers on my truck
« Last Edit: August 23, 2011, 09:09:56 PM by penski61 » Logged
akuria
« Reply #4 on: August 23, 2011, 09:22:25 PM »
so waggy axles are closer to the pathy widths?
« Reply #5 on: August 23, 2011, 09:25:17 PM »
yeah , waggy's are 60.5  the pathfinders are 59"  the ford is  65-1/2
akuria
« Reply #6 on: August 23, 2011, 09:29:09 PM »
Great. thanks so much for the info.
