July 22, 2018, 03:46:30 AM *
Author Topic: taurus fan install  (Read 8499 times)
« on: July 09, 2011, 05:54:14 PM »
so i had to fix the timing belt i guess it skipped a tooth , i figured since i had everything apart i might as well do an e-fan
picked up a Taurus fan from T-ray  went to metal shop and then started this
pretty much done , i had to notch the drivers side to clear the steering box
tomorrow ill see if i can get installed and wired up
« Reply #1 on: July 10, 2011, 09:25:27 AM »
other than some mounting brackets , its done
oh and welding aluminum sucks lol , good thing is that its not a structural weld
radiator is back in , now just have to wait for the kit to show up
« Last Edit: July 10, 2011, 04:24:15 PM by penski61 » Logged
salad_man
« Reply #2 on: July 10, 2011, 07:10:59 PM »
That looks sweet, let me know what fan and kit, as I would like to do this on my truck as well.
93 4Runner, Land Crusier rear coils, BJ spacers up front, 33x12.50 bfg m/t, rear e-locker, and some armor.
Call Sign: KJ6GQS
"Roads? Where we're going, we don't need roads."
                                        - Doc, Back to the Future
« Reply #3 on: July 10, 2011, 07:18:44 PM »
its the 2 speed ford taurus fan , the kit im wanting to get has a 2 week lead time so i may end up getting something different
i cut the original ford fan shroud down just what you see in the pics otherwise it wouldnt have worked just bolting it to the aluminum shroud
also the ford shroud didnt even come close to the coverage this shroud has
« Last Edit: July 10, 2011, 07:29:03 PM by penski61 » Logged
salad_man
« Reply #4 on: July 10, 2011, 09:07:09 PM »
Where are you getting the kit from? I am assuming you are just getting a thermostat kit, will that be with a tapped in sensor on the radiator?
Call Sign: KJ6GQS
« Reply #5 on: July 10, 2011, 09:10:03 PM »
i paid for this kit , but i didnt see a 2 week lead time so i may get a refund and  go with something different but ive heard alot of good things about this kit
http://www.dccontrol.com/fancontrol.htm
found this one that is similar
http://www.summitracing.com/parts/FLX-31165/?rtype=10
« Last Edit: July 10, 2011, 09:26:23 PM by penski61 » Logged
salad_man
« Reply #6 on: July 10, 2011, 09:59:40 PM »
oh very nice, I was looking at the flex a lite fans before as well.
Call Sign: KJ6GQS
« Reply #7 on: July 14, 2011, 07:43:09 PM »
got it all wired up
used a 50 amp circuit break for high and 30 for low , 2 75 amp relays and a 3 way switch to control it for now
i may install the control i order but ill probably just sell it
turned it on the other night and worked great but had to shut it off cause i was running open headers and the truck was way too loud
salad_man
« Reply #8 on: July 14, 2011, 09:02:57 PM »
Why not install the thermostat control?
Call Sign: KJ6GQS
« Reply #9 on: July 14, 2011, 09:21:41 PM »
cause its not here lol , and apparently it takes 3 weeks to get here
i should have done research on this guys customer service before i ordered but his product is highly recommended
« Reply #10 on: July 17, 2011, 08:25:25 PM »
