April 24, 2024, 02:04:07 AM *
Pages: 1 2 [3] 4 5 ... 8
Author Topic: Nissan Frontier 3 Link Front & 4 Link Rear & 5:1 Atlas  (Read 174713 times)
« Reply #50 on: August 28, 2011, 06:13:27 PM »
so hows it going?
« Reply #51 on: August 29, 2011, 11:53:20 AM »
excellent.  Thumb-Up
Pics and Vids to come...
« Reply #52 on: August 29, 2011, 05:17:56 PM »
well here is one pic from this weekend , Natalie is cleaning up the other ones
checking clearance and what needs to be changed , everything worked pretty much flawlessly
only changes are charge the coilovers to 200lbs since we only had a pre-set regulator , move the coilovers up about 2" in the back and adjust the rear uppers one hole up
« Reply #53 on: September 05, 2011, 02:57:43 PM »
ruggedrocks 4 link brackets
axle side upper link brackets were custom , lowers were ruffstuff
ruggedrocks has the upper link brackets for the h233b
front upper link axle side and frame bracket custom
also definatly go with adjustable uppers vs weld on
« Last Edit: March 18, 2012, 08:34:39 PM by penski61 » Logged
« Reply #54 on: September 05, 2011, 08:17:03 PM »
Now that's a real truck!  No leaf spring nonsense.   Cool
I have your sledge hammer BTW.
« Reply #55 on: September 06, 2011, 11:10:09 AM »
That truck came out so nice.  cheers
salad_man
« Reply #56 on: September 06, 2011, 04:44:52 PM »
Does look good
93 4Runner, Land Crusier rear coils, BJ spacers up front, 33x12.50 bfg m/t, rear e-locker, and some armor.
Call Sign: KJ6GQS
"Roads? Where we're going, we don't need roads."
                                        - Doc, Back to the Future
« Reply #57 on: September 06, 2011, 06:15:10 PM »
haha i totally forgot about that thing , oh well
« Reply #58 on: September 25, 2011, 12:48:30 PM »
well the rear coilovers were too far inboard which was cause the rear to completely flex when the front was on a 3 ft rock and the front wasnt doing much of anything
ill get some better pics later today
« Last Edit: March 18, 2012, 08:35:38 PM by penski61 » Logged
« Reply #59 on: September 25, 2011, 07:04:17 PM »
« Last Edit: March 18, 2012, 08:37:21 PM by penski61 » Logged
« Reply #60 on: September 27, 2011, 01:01:39 AM »
Very nice Arron!  That is really the best way to mount the coilovers.  How far out are you moving the axle side mounts out?  I think if you move them out enough, like about 5", that should keep the tires from rubbing at full stuff.  Did you drop down the upper mounts a little?
« Reply #61 on: September 27, 2011, 07:16:20 AM »
i havent welded the lower shock tabs on yet but im trying to keep the coilovers at atleast a 75 degree angle no less but i think when i measured last its about 6-7 inches away from the axle flange
i had already moved the lowers up from when we set them and it worked perfect , i also moved the axle foward about 2"
oh ps its Aaron  Grin you just doubled the wrong letter
« Reply #62 on: September 27, 2011, 09:43:30 AM »
Doh!
I would shorten the lower shock tabs back down to keep the same tire to fender clearance.  I calculate you'll loose about 2"  articulation if you outboarded the mounts 5" on each side.
« Reply #63 on: September 27, 2011, 07:03:05 PM »
2" up travel or down travel? i have them setup for 5.5 up and 8.5 down  , the lower mounts are pretty much lined up with the front lower mounts if your looking from the back of the truck to the front
i have the same amount of clearance between the fenders front and rear and i just barely touch on the front with 5.5 up 8.5 down
overall the lowers were outboard 7-1/2" from where the were and the uppers about 4"
« Reply #64 on: September 29, 2011, 08:25:59 PM »
i got what you meant Kenny
i was able to lower them 1"  but couldnt go any lower than that
« Reply #65 on: October 01, 2011, 08:22:08 AM »
all finished up , the work was well worth it the truck handles alot better cornering and it flexes pretty much even front to back now Cheesy
« Last Edit: March 18, 2012, 08:40:14 PM by penski61 » Logged
« Reply #66 on: October 03, 2011, 09:18:21 AM »
right on man. have you flexed it out yet?
« Reply #67 on: October 03, 2011, 12:15:14 PM »
just on the trailer but it seems to be working Wink , ill get a good test this weekend
« Reply #68 on: October 12, 2011, 11:54:12 PM »
Excellent!  That's the way it should be.
« Reply #69 on: October 19, 2011, 07:34:08 PM »
new t-case skid/slider
« Reply #70 on: November 07, 2011, 05:03:14 PM »
new higher clearance front bumper
« Last Edit: March 18, 2012, 08:41:31 PM by penski61 » Logged
« Reply #71 on: November 07, 2011, 08:45:37 PM »
nice!
I like this one man!
« Reply #72 on: November 09, 2011, 12:19:47 PM »
I like that much better!  No more leaf brackets! lol
Hey, is that a true dual exhaust I see now?  I miss the way mine sounded.   Sad
« Reply #73 on: November 09, 2011, 05:25:13 PM »
yep true duals with 24" cherry bombs , sounds pretty good  Grin
« Reply #74 on: January 02, 2012, 02:03:31 PM »
from this weekend
