April 25, 2024, 09:39:43 PM
Welcome,
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News
: View our New trail run pictures in the
Image Gallery
Home
Help
Login
Register
Rugged Rocks
General Discussion
> Topic:
how to tighten up front end on 1995 pathfinder ??
Pages: [
1
« previous
next »
Author
Topic: how to tighten up front end on 1995 pathfinder ?? (Read 10491 times)
FUELER
Offline
qx4x4
on:
March 31, 2011, 08:46:10 PM »
Hey guys,
working on a 1995 Pathfinder for another Baja trip. Getting the steering tight - The front sway bar is loose on its mounts and the front lower ball joints are shot.
Do you have any recommendations for aftermarket parts?? Like aftermarket sway bar mounts or strong aftermarket lower ball joints?? Looking for stronger than stock!!!
Thanks!!
Adam AKA FUELER
id rather be in Baja
Offline
Re: how to tighten up front end on 1995 pathfinder ??
Reply #1 on:
March 31, 2011, 11:53:10 PM »
which sway bar mounts are loose? the end linkage or the mounts to the frame?
on the lower BJ's I think you're out of luck
Rugged Rocks Newsletter
| Check out my articles on
CrawlerNews.com!
Offline
Reply #2 on:
April 01, 2011, 10:07:14 AM »
for swaybar links, you could probably find an energy suspension part that would fit. They make good long lasting stuff.
as for ball joints, you're SOL with and upgrade, its stock or nothing.
DIY OBA
DIY snorkel
DIY Paint Can Air box
Build Thread
Offline
Reply #3 on:
April 04, 2011, 04:32:16 PM »
You can get the sway bar bushings cheap at pep boys. They have just the bushings or you can use an energey suspension end link set. All that stuff is under $15.
If it's the front sway bar bushings, here is what has worked for me. Get the set that has the poly bushings throw away the :hit:mounts that come with them, stuff them into the factory mounts and run them. I've torn several sets of the ES mount pieces before just stuffing them into the more heavy duty factory ones.
You can get lower ball joints at Napa, just have to get ones for a frontier (this works for Xterras). Just make sure the LCAs are physically the same; if they are, then you can run them. They have both tabs plus have to be pressed out. It's a big PITA. Again, you'll have to check cross-compatibility with the frontier.
A new set of idler arm bushings may go a long way to tighten up the steering; check there for play. This is common and the bushings are cheap.
Hope this helps.
Pages: [
1
Rugged Rocks
General Discussion
> Topic:
« previous
next »
Please select a destination:
Rugged Rocks
=> Solid Axle Nissan Pathfinder Project
=> Announcements and Updates
=> New Member Check-In
=> Vehicle Showcase
=> General Discussion
=> Off Topic
On The Trail
=> Trail Runs and Events
=> Trail Run Reports
=> Trail Closures and Updates
=> GPS & Mapping
=> Communications
Vehicle Specific
=> D40 Frontier
=> N50 Xterra
=> R50 Pathfinder
=> D22 Xterra / Frontier / Navara
=> D21 Pathfinder / Hardbody / Terrano
=> 720
=> Patrol
=> Rock Buggy
=> Trailers and Towrigs
=> Jeeps, Toyotas 'n Other Stuff
Classifieds
=> Parts For Sale
=> Rigs For Sale
=> Parts Wanted
Loading...
