April 25, 2024, 10:04:52 AM *
Author Topic: rear driveshaft  (Read 26496 times)
« on: March 01, 2011, 02:45:27 PM »
wb is 120" and because of that i would constantly hit the driveshaft , so i decided to try a thicker wall driveshaft which held up for 2 runs and had to get rebalanced twice , this time i decided to go with even thicker wall (suggested by the builder)
put the driveshaft on the truck and truck wouldnt get out of its own way , and i was running 2500 rpms where as before i was at 2100
so now im cutting down the driveshaft they re-tubed and goin with a 2 piece design that will give me about 3" more clearance at the point i kept hitting before
ill post pics of the finished project but here is a mockup of before and after
oh and if i do for some reason i mess up the driveshaft i can pull it out swap the front to the back and go rear wheel again , but more than likely will get a trail spare in the future
« Reply #1 on: March 01, 2011, 08:14:58 PM »
I'm running 3/16 wall.  It's a heavy bastard, but seems to run OK.  I wouldn't think the weight would affect the performance much while just cruising, just heavy acceleration.  Clearance looks good with the two piece.
« Last Edit: March 01, 2011, 08:19:49 PM by theking » Logged
« Reply #2 on: March 01, 2011, 08:32:32 PM »
when your up to speed its ok , its was getting to cruising speed that was the BIG problem lol
i had 3/16 on the truck before this and it was alright but i kept hitting the DS at pretty much the same spot
so im hoping this will help out a bunch to where i dont hit the stupid thing
the advantage ill have now is the front and rear driveshafts will be pretty much the same thing , so if i want to i only need one spare driveshaft
« Last Edit: March 01, 2011, 08:34:57 PM by penski61 » Logged
« Reply #3 on: March 01, 2011, 11:37:01 PM »
I like the idea.  Let us know where you source the carrier bearing, if you would.  I might need one for a rig I'm working on.    cheers
« Reply #4 on: March 02, 2011, 04:07:39 PM »
im having the front section made up by a local driveshaft shop , same place that has done pretty much all my stuff
the front section is gonna run around $155-165 , then the second half is just the normal driveshaft with high angle cv  and 9" slip
« Reply #5 on: March 02, 2011, 06:06:55 PM »
i think this is gonna work out better than i hoped
here is the driveshaft cut down and i have even more clearance than mock up and better angles as well!!
i should be able to just shim but ill have to re-do the shock mounts in the back
« Reply #6 on: March 04, 2011, 06:44:13 PM »
tried shims but wont work with the anti-wrap perches so need to cut and rotate then make a new x-member to mount the carrier bearing to
« Reply #7 on: March 05, 2011, 12:32:21 PM »
it looks good, wondering how it will hold up, I might be redoing my rear, ha ha
« Reply #8 on: March 05, 2011, 12:53:50 PM »
got the x-members almost in , taking a lunch break then need to finish welding them up then comes out the driveshaft and the rear axle
got to cut the spring perches off and rotate the axle up , im hoping to get it done and do a test run to see how the balance is
« Reply #9 on: March 06, 2011, 07:27:17 PM »
got everything all put back together
few pics of full droop and the x-member
« Reply #10 on: March 13, 2011, 09:04:22 AM »
and now the carrier bearing and yolk protected Smiley
« Reply #11 on: March 13, 2011, 09:33:52 AM »
thats awesome! Thumb-Up
« Reply #12 on: March 13, 2011, 10:17:40 AM »
thanks  Grin, im hoping it should do the trick
before and after shot
« Reply #13 on: March 13, 2011, 10:21:48 AM »
Thats cool.  I like that.
« Last Edit: March 15, 2011, 02:16:40 PM by BlackX » Logged
« Reply #14 on: March 14, 2011, 05:45:13 PM »
Looks great
« Reply #15 on: March 14, 2011, 07:06:01 PM »
are you gonna link it?
« Reply #16 on: March 14, 2011, 08:29:11 PM »
that is the plan but probably wont be for a while
if i do link ill swap the housing to a ruffstuff housing or spidertrax
maybe ill make a trip out to cali and enlist the help of a guy that does some awesome work  Thumb-Up
« Last Edit: March 14, 2011, 08:35:47 PM by penski61 » Logged
« Reply #17 on: March 14, 2011, 09:33:01 PM »
Wow, that looks cool!  Nice to have solid welding skills!
« Reply #18 on: March 14, 2011, 10:03:39 PM »
yeah you know, i know a guy. Thumb-Up
