April 26, 2024, 08:09:36 AM *
Author Topic: engine oil cooler  (Read 8489 times)
« on: October 13, 2010, 08:23:38 AM »
for those thinking about adding an engine oil cooler , heads up for ya if you use this kit
flex-a-lite part # FLX-3951
you need to grind the alternator bracket back quite a bit and you cant use the oem filter because the filter is not big enough in diameter to cover the sandwich adapter
i went with the fram 3950 because it was the correct thread pitch and the O-ring was the correct size to cover the sandwich adapter
and the clearance (its not much lol)the new filter has after grinding the alternator bracket
size comparison
and the cooler (which is kind a hard to see)
