April 16, 2024, 11:50:52 AM *
Author Topic: What's up with the upcoming SAS kit?  (Read 16604 times)
« on: July 21, 2010, 08:32:03 PM »
Steeevo, any word?  I've been curious about this since we talked at the field day.
Any word?  What's it going to entail?  I was looking over the axle I've got and am thinking about getting the plan together finally.
« Reply #1 on: July 22, 2010, 12:12:50 AM »
I'm swapping out the D44. my new axle will be here in about 2 months then the truck goes under the knife. getting all new suspension front and rear. everything that goes onto the pathy will be available in kit form.
« Reply #2 on: July 22, 2010, 12:12:10 PM »
I guess I'm just curious about the details/components of what you're envisioning (link type, what would be needed, etc.)
I'm getting going slowly, but don't want to start piecing things together until I have more of a plan in place. I'm curious because if what you're working on comes together would work out, I'd like that to be an option.
« Reply #3 on: July 22, 2010, 02:35:44 PM »
ah ok. It'll be a 3-link on 14" short body remote reservoir radflow coilover shocks.
I'll be using the front H233B diamond axle. which i'll make available with all the required brackets welded on for the SAS.
What size tires are you planning on running?
I'll be running 37's on the pathfinder but using 12" coilovers on 35's shouldn't be a problem.
« Reply #4 on: July 22, 2010, 05:51:55 PM »
I'm planning on 35s.  I have a D44 from a Waggy (not full width) and have a line on 12" coilovers in either a 32- or 36-inch length, but I'm thinking the 32-inchers would be the way to go.
« Reply #5 on: July 23, 2010, 12:17:40 AM »
yup the 32's will work out better in your case.
just an fyi I don't have any immediate plans for making brackets to fit the D44 with the kit.
KovemaN
« Reply #6 on: July 27, 2010, 02:13:59 PM »
Bummer about the brackets.  I was planning on the Waggy D44 as well.  I highly doubt I will be able to find another set of H233b gears for $250. Are you going to have the option to purchase the frame side brackets separately?
« Reply #7 on: July 27, 2010, 05:05:19 PM »
I found the OE gear cutter for H233B gears. once i get my hands on them, Retail price will be around $250 for 5.14, 5.57 & 5.87. These are brand new gears from the OE gear cutter. I have a source for 5.42's but are Non-OE and are far too expensive. 4.88's are still in the air. probably won't order any 4.88. but if i do the retail price will also be around $250
frame side brackets and links, track bar and coilover hoops will be as a kit.
edit:
It turns out that i have to order 100 sets of each ratio at a time... still trying to pull strings.
I'll be looking at turning out 5.14s first.
« Last Edit: July 27, 2010, 08:49:34 PM by SteeevO » Logged
KovemaN
« Reply #8 on: July 28, 2010, 09:43:58 AM »
$250 is much better than $450-500.  Any idea how much complete Diamond front axle will run?
« Reply #9 on: July 28, 2010, 03:44:16 PM »
I'm not sure on that yet but my front axle housing is due to be in in about a month and i'll be getting numbers together soon after.
KovemaN
« Reply #10 on: August 05, 2010, 09:36:20 PM »
The 5.14s I got were 36:7.  I'm pretty sure they originally came from AC.
mikeyjm1
« Reply #11 on: October 11, 2010, 05:49:37 AM »
any more updates on the axle or, the gears, or the kit?
« Reply #12 on: October 11, 2010, 10:19:31 AM »
nope not quite yet.
