April 26, 2024, 08:04:48 AM *
Author Topic: goin with a ford 9"  (Read 35037 times)
« on: April 02, 2010, 05:37:10 AM »
well decided i should go a different route instead of keeping the yota axle(not sure if ill have it for MOAB) , i went ahead and picked up a ford 9" housing got it all cleaned up and made an untraditional truss lol
i did it this way because im still running leafs in the back and didnt want to have worry about the getting the u-bolts to work with a traditional truss
i shall call it , the slider truss   Cheesy
« Reply #1 on: April 02, 2010, 08:11:49 AM »
Why are you ditching the Toyota axle?
« Reply #2 on: April 02, 2010, 08:18:16 AM »
to better match the gears i have up front so i would have 5.38's and 5.42's vs 5.38's and 5.29's , also  the inside of the yota axle housing is rusted because the guy i bought it from let water sit in it
i cleaned the inside of the housing as best as i could but not sure i trust the housing
so it was either get a stock , aftermarket or go with a different setup
also this will be full length with custom axle shafts made for 6x5.5 bolt pattern so i dont have to run adapters in the back
« Last Edit: April 02, 2010, 08:20:26 AM by penski61 » Logged
« Reply #3 on: April 02, 2010, 06:08:39 PM »
then cleaned the axle up better today , plated the bottom of the axle with 1/4" and added a rear skid
« Reply #4 on: April 02, 2010, 07:32:58 PM »
you gonna make it a full float?
« Reply #5 on: April 02, 2010, 07:51:56 PM »
no , trying to do it on the cheap right now to get it in before Moab
35 spline 6x5.5 axle shafts with ford 8.8 rear disks 5.42's and detroit
« Reply #6 on: April 03, 2010, 12:35:04 AM »
You gonna run a Strange pro nod, hi9, or Currie center?
« Last Edit: April 03, 2010, 12:42:47 AM by theking » Logged
« Reply #7 on: April 03, 2010, 09:21:48 AM »
im not sure the guy putting the axle together is doin that stuff , he does some of the work on KOH rigs
letzroll is the guys shop here in mesa
« Reply #8 on: April 05, 2010, 09:53:10 PM »
strange pro nod with datona pinion support and pinion guard
« Reply #9 on: April 05, 2010, 09:59:04 PM »
Ah yes.  I just stumbled on his online shop looking at PSC steering stuff.
Yah,  you need the big bearing gear case for 35 spline.  Them gear cases are a little pricey.  That's what deterred me from a 9".  But, it should be a nice light and strong setup.
« Reply #10 on: April 05, 2010, 10:07:36 PM »
all said and done ill have about $1500 into the axle which isnt to bad completly built
the housing and tubing i got for $63
got new spring pads and i may be able to re-use the shock mounts off the yota axle
« Last Edit: April 05, 2010, 10:09:22 PM by penski61 » Logged
« Reply #11 on: May 15, 2010, 12:23:57 PM »
Do you have to worry about the axle tubes warping when welding the truss and the skid?
What's the full float about?  The only thing I remember was that you could pull your axle shafts out w/o taking everything apart, and it has something to do with the bearings.
alexrex20
« Reply #12 on: May 17, 2010, 06:23:26 PM »
a full float basically uses a stub shaft that engages the axle, which then engages the differential. the weight of the vehicle is supported by the stub shaft/hub, so if you bust an axle, you can remove the axle and still drive home.
« Reply #13 on: May 17, 2010, 09:20:50 PM »
yep what he said
as far as welding , yeah i welded a little section let it cool and went side to side
to avoid warping the housing hopefully it worked haha
« Reply #14 on: June 13, 2010, 10:51:52 AM »
few pics of the housing mocked up along with a cross member for a possible 4 link or just an anti-wrap bar
« Reply #15 on: June 14, 2010, 03:23:17 AM »
I noticed you inboarded the lower shock mounts.   cover
« Reply #16 on: June 14, 2010, 07:40:17 AM »
does it help to have them on the outside of the springs? pretty much all shock are setup inboard arent they , mine have been setup up this way pretty much since i had the truck and no issues
if i need to i could build shock hoops and put them on the outside of the frame and springs
« Reply #17 on: June 14, 2010, 10:43:50 AM »
It does make a difference in handling with them mounted as wider.  My shocks are mounted like that, but I wish I could push them all the way to the tires.  That would also help limit wheel travel.  But, there's just no room, though.
« Reply #18 on: June 14, 2010, 10:46:28 AM »
cool , i got some more tubing
ill do a mock up and see what you think
« Reply #19 on: June 14, 2010, 12:50:37 PM »
so this is about how much room i would have if i ran the 1.5" spacers in the back
« Reply #20 on: June 14, 2010, 03:34:41 PM »
one side done
« Reply #21 on: June 14, 2010, 08:15:13 PM »
Looks like it will clear the frame with them upsidedown.  I would set the uptravel as a bump stop to keep the tire from rubbing the fender.  Bad thing about leafs is you can't flex it to test fit stuff.
I bet it will handle much better on the street, now.
« Reply #22 on: June 14, 2010, 08:23:38 PM »
there is 2" between the shock and frame and 4" between the inside of the tire and the shock if i run 1.5" spacers
« Reply #23 on: June 15, 2010, 01:11:16 AM »
2" is close.  But, it all depends how much flex you get with those leafs.  My 3 link has a high roll center, so the shock moves in a lot on the drooped side.  That setup would never clear the frame on mine at full flex.  But, leafs have a low roll center, so you might be ok.  Def. run the spacers and go flex it out. lol
« Reply #24 on: June 15, 2010, 10:43:25 AM »
But.. i think you're going to have to mount them the right way.
I wouldn't run them upside down.
