May 15, 2024, 02:19:55 AM *
Author Topic: 2004 SE/SC Dynatrac SAS Xterra For Sale - Expedition Style  (Read 26283 times)
expeditionxterra
« on: July 15, 2013, 02:10:56 PM »
This is not a distress sale. I don't need to sell it, but it would help get a good start on the new build up.
PRICE: $18,000.00 OBO
Email jason@seeksolitude.com
2004 Nissan Xterra 4x4 SE/SC Supercharged 3.3L V6
Shrockworks Front Winch Bumper
Shrockworks Rock Sliders
GOBI Ranger Hybrid (prototype) Roof Rack
WARN 9000i Winch (synthetic rope)
GOBI Rear Ladder
GOBI Shovel/Axe mount
GOBI Pull-Pal Mount
Pull-Pal 11,000lb Recovery Anchor
Skid-Row Automotive Rear bumper (custom tire carrier)
ARB Safari Snorkel
5.14 Ring an Pinion 33 Spline gears
3.7 to 1 Low Range Transfer Case Gears
ARB Air Locker for H233B Rear Axle
ARB Air Locker for Dana 60 Front Axle
ARB Compact on board Air Compressor
2" Body Lift
Custom Solid Axle Front End w/Dynatrac Pro-Rock 60
Kick *** Offroad Rear Sway Bar (custom)
Light Racing Jounce Shocks (rear)
FOX 2" Piggy Back Rear Shocks
FOX 2.5" Resevour front coil-over shocks dual rate
Custom Deaver Leaf Springs (rear)
Custom Front Drive Shaft
American Racing Mojave Teflon Wheels (5)
On-Board Hot water shower system
Kodiak Dual Battery system
Odyssey 1750 (front)
Odyssey 2150 (rear)
Odyssey 2150 (rear)
PIAA Side Lights (2)
PIAA Reverse Lights (2)
WARN SDB-160 Dual Beam Lights (2 sets)
Eezi-Awn 1200 Roof Top Tent
Front Runner 5GAL Water Tank
Touch Tek 6 Power Management System
Gamber Johnson Custom Center Console
7-Wire Trailer Harness Tekonsha P3 Controller
Xantrex 2000 watt pure sinewave inverter/charger
Raingler Interior X-Net
Toyo Open Country MT 35" Tires (60%f 20%r 100%sp)
Calmini Slip Yolk Eliminator
Custom Front Skid Plate Laser Cut "XXXTerra" Stainless
B&M Aux Tranny Cooler
Engel 45 Fridge Freezer (slide lock, transit bag)
Under Frame Rock Lights (tractor)
DUALPRO Three bank battery monitor
Rig Runner Power Distribution Panels (3)
AutoMeter Guages (air, tranny, volt)
K&N Drop-in air filter
Dual pusher aux cooling fans
Kodiak 200 Amp alternator
Custom deck where rear seats used to be, Line-X coated and drilled for Engel slide-lock hold-downs for boxes
Custom aluminum deck in rear of vehicle line-x coated, slide-lock drilled for fridge, cases, and 5gal water tank
Custom Lightbar made specifically for the GOBI rack, includes three antenna mounts (has dual 2m/70cm and a wide band scanner antenna)
Dual antenna ports in the rear of the GOBI rack
Hi-Lift Mounted on rear bumper
Eezi-awn ladder extension
LED Light flush mounted in deck of rear hatch
LED light mounted inside Eezi-Awn Roof Top Tent
Fluorescent camping light on the bottom of the Eezi-Awn which lights a very large area under the tent when deployed
Rig Runner power panel inside Eezi-Awn, which I used to run a fan and some other goodies.
gobi03 by sotagoat, on Flickr
20130223_120813 by sotagoat, on Flickr
mojave08 by sotagoat, on Flickr
expeditionxterra
« Reply #1 on: July 15, 2013, 02:31:24 PM »
A couple of videos Cheesy
https://www.youtube.com/watch?v=VgQ8ZnBjkQs
https://www.youtube.com/watch?v=5bz1GnViBR8
« Reply #2 on: July 15, 2013, 05:39:48 PM »
Is the icom ic-7000 included?
« Reply #3 on: July 15, 2013, 06:27:42 PM »
mileage?
skibum315
« Reply #4 on: July 15, 2013, 08:03:41 PM »
For-sale thread on the Expedition Portal Forum ... has a link to the build thread, too:  http://www.expeditionportal.com/forum/showthread.php?t=95097
expeditionxterra
« Reply #5 on: July 16, 2013, 09:55:10 AM »
mileage?
110,000
expeditionxterra
« Reply #6 on: July 16, 2013, 10:09:38 AM »
No, I removed the radios since the last person who wanted to buy it wasn't a ham.  That is also why the radios aren't in the list of equipment.
expeditionxterra
« Reply #7 on: July 16, 2013, 10:13:17 AM »
Another note on this:  The power and antennas are still on the truck, even the mounting plate on the floor.  Everything is ready for radios to be installed.
